Subject:
Technical compatibility question: 24V 10mm RGBCCT COB LED strip with WS2811 and MiBoxer SPI controllers
Dear MiBoxer Technical Support Team,
I am planning a project using a high-density 24V addressable RGBCCT COB LED strip and MiBoxer control equipment.
I would like to ask your engineers to confirm compatibility at the protocol/IC level.
The exact LED strip I am considering has been confirmed by the manufacturer with the following specifications:
IC: WS2811
Voltage: DC24V
840 LEDs/m
PCB width: 10mm
12 WS2811 ICs/m
Cutting interval: 83.33mm
Power: 26W/m
RGB+CCT / RGBCW
Addressable / digital SPI strip
The manufacturer confirms that this is a WS2811-based RGB+CCT/RGBCW implementation.
MOST IMPORTANT QUESTION
CAN THIS EXACT WS2811-BASED RGB+CCT/RGBCW STRIP BE CONTROLLED CORRECTLY BY ANY OF THE FOLLOWING MIBOXER SPI CONTROLLERS?
SPIR5
SPIB5
SPIW5
SPIW5-4
SPI-WL4
For EACH controller, please provide one of these answers:
COMPATIBLE
NOT COMPATIBLE
NOT TESTED
Please check RGB+CCT / RGBCW operation specifically, not only RGB operation.
WS2811 RGB+CCT ARCHITECTURE
There is an important technical point.
WS2811 itself is a 3-channel IC. Therefore, I understand that some addressable RGB+CCT strips use multiple WS2811 ICs to implement the five RGB+CCT channels.
CAN YOU CONFIRM WHETHER YOUR CONTROLLERS SUPPORT THIS TYPE OF DUAL-WS2811 RGB+CCT ARCHITECTURE?
If yes:
How should the MiBoxer controller interpret the two WS2811 ICs?
Does one IC control RGB and the second IC control WW/CW?
Does MiBoxer treat the two ICs as one logical RGB+CCT pixel?
Is any special IC/protocol setting required?
Is this configuration supported directly by the controller firmware?
WE NEED RGB + WW + CW TO WORK AS FIVE INDEPENDENT CHANNELS. IT IS NOT SUFFICIENT IF THE CONTROLLER ONLY RECOGNIZES THE STRIP AS RGB.
IC / PROTOCOL SETTINGS
WHICH EXACT IC/PROTOCOL SETTING SHOULD BE SELECTED IN THE MIBOXER CONTROLLER FOR THIS STRIP?
Is it simply:
WS2811
or is there a specific RGB+CCT / RGBCW / dual-IC setting?
If there is a specific firmware version or IC configuration required, please provide it.
12 ICs/m and 83.33mm pixel structure
The manufacturer specifies:
12 ICs/m + 83.33mm cutting interval.
CAN YOU CONFIRM HOW MIBOXER INTERPRETS THIS STRUCTURE?
In particular:
How many logical RGB+CCT pixels/m are supported?
Are two WS2811 ICs used for one RGB+CCT pixel?
Does the controller maintain correct addressing through the entire strip?
Can dynamic effects run continuously across the entire strip?
10-meter installation
My initial installation will be 10 meters.
The strip is rated at:
26W/m × 10m = approximately 260W / 10.8A at 24V.
The strip will have separate power injection, rather than forcing the entire 10m load through the controller output.
CAN YOUR ENGINEERS CONFIRM THE CORRECT POWER/DATA WIRING FOR A 10-METER INSTALLATION WITH THIS STRIP?
In particular:
Should power be injected at multiple points?
Should the controller carry only the data signal while the 24V power is distributed separately?
Are there any limitations on the maximum addressable length?
B9 / B9-W compatibility
I also intend to use a MiBoxer B9 / B9-W wall panel.
WHICH OF THE FIVE CONTROLLERS ABOVE CAN BE PAIRED DIRECTLY WITH THE B9/B9-W AND CONTROL THIS WS2811 RGB+CCT STRIP THROUGH THE PANEL?
Please distinguish between:
controller supports the strip;
controller supports B9/B9-W;
controller supports both simultaneously.
Final question
IF NONE OF THESE FIVE CONTROLLERS CURRENTLY SUPPORT THIS EXACT WS2811 RGB+CCT CONFIGURATION, DOES MIBOXER HAVE ANOTHER CURRENT OR SPECIAL SPI CONTROLLER/ FIRMWARE THAT CAN SUPPORT IT?
If possible, please ask your engineering department to verify this technically, rather than relying only on the general product description.
I am asking because the project is not a one-off purchase: the initial requirement is 10 meters, and if compatibility is confirmed and the system works correctly, I may purchase 50 meters or more.
Thank you in advance for a precise technical answer.
Best regards,
Kais.
