How to change frequency (250HZ to 8KHZ)for LED controller?
8KHZ:Press “OFF” button 1 time within 3 seconds and press “ON” button 5 times, Activated successfully once led light flashes 2 times quickly.
250HZ:Press “ON” button 1 time within 3 seconds and press “OFF” button 5 times, Activated successfully once led light flashes 2 times slowly.
Warm tips: user can change low frequency(250HZ) to avoid the beep noise from mains, checking video
How do you do this if your only controller is the K1? It doesn’t seem to work…
