FUT086 remote not linking up properly with PW01 LED pool light
Hi,
Current set up:
I have installed 2 PW01 ( 27W RGB+CCT PAR56 LED Pool Light (LoRa 433MHz) ) pool lights and will use the FUT086 (8-Zone LoRa 433MHz ) remote to control them. Both pool lights have power and is working. The remote control has new batteries and is working. A red light is showing when keys are pressed.
Problem statement:
When power is turned on I have, within 3 seconds of power on, grouped the two pool lights to the master on/off buttons and to the on/off buttons in zone 1. This means I can turn the two pool lights on and off with the master buttons. I have also grouped the two pool lights to zone 1 on/off buttons following the instructions. This is all I can do with the remote at the moment.
PS! I have also linked and un-linked the pool lights and remote in several rounds with out any improvements to the below issues.
The two pool lights are now not in synch and are blinking different colors. This can not be controlled by the remote by pressing the M button to change the dynamic mode. Also, pressing the button W for White light is not responding.
I have tried all tricks found by AI and google but I have not managed to control the blinking of different colors and switch the color to white.
Please advice on how to proceed to be able to stop/control the blinking and control the color setting on the pool lamps, including setting both lamps to white at the same time, using the FUT086 remote control.
Also, please advice if it would work better (need assurance on this due to extra cost) to use the 433MHz Gateway Model No.: WL-433 and the app for iPhone .
Looking forward to your response.
Thank you.
Best regards,
Ivar
@Jesson Can you please have a look at my issue?
I really need to get these pool lights to work properly. They are still blinking all colors and will not be controlled by the FUT086 remote, except turn off and on.
Copilot is suggesting the two lights are stuck in dynamic/demo mode or did not exit power -on demo mode, whatever that is.
When installing the lights I connected both to power and they started blinking. The user manual is not suggesting to do anything else then turn off power again, wait 10 seconds, turn on again and withing 3 seconds press the 1 button on zone 1 5 times.
So my questions is, to avoid getting into to much details, what is the “trick” to get the two lights in learning modus and connect to the remote control FUT086? Take it all the way back from the beginning , when the lights are installed and connected to power. Should one light be installed first and linked to the remote and then the other or all at once?
I would appreciate any advice, tips or tricks that would help me resolve this issue. Thank you very much for your support.
Best regards,
Ivar
Hi Ivar,
Were you able to resolve your issue?
I seem to be having the same problem with my two PW01 bulbs and my FUT086 remote control.
Thank you in advance.
