I use the driver in a motorhome on the awning. The car automatically disconnects the power when driving, after the second drive it always turns on automatically (“do not disturb” function). I would like to have the memory function after power is restored even if I turn off the power several times. Thanks!
So you need the power is alway OFF while driving away, correct ? Do you activate " do not disturb" function on the controller?
Every time I start the car, the power automatically turns off. If I do multiple starts, the lights are always on in “do not disturb” mode
If I disconnect the power more than once, the lights will always be on. Why??? This is an incomprehensible function. Why doesn’t it have a normal memory of the last state?
Did you install the controller in your car and powered by car battery ? Actually if you activate “Do not disturb” mode, the light should be OFF once you stop car and light should be on once you drive car, that’s what you need, right ?
No, I don’t need that. When I start the car, the power to the lights is cut off for safety reasons. If I start it 2x or more, the power is cut off 2x in a row. If I cut off the power 2x or more in “do not disturb” mode, the lights will always be on after the power is restored. I need the lights to be off after the power is restored even if I turn off the power 2x or more in a row.
