DL-X DALI 5-in-1 LED controller: RGBCCT Lamp Failure
I have installed a couple of DL-X drivers connected to RGBCCT LED strips. The drivers are controlled by a KNX ABB DG/S 1.64.5.1 DALI Gateway and properly recognized with 5x channels.
Although I can control the strips, the DALI device returns a lamp failure:
  • when the strip is off
  • when it’s on, at some point while it’s in operation.
Why does the DL-X return a lamp failure, when all 5x channels are properly connected and checked?
This is causing problems with status feedback
Hi, the issue is caused by system compatibility limitations
Hello,
Thank you for replying.
Could you please elaborate a bit on the compatibility limitation details ? Perhaps it may help me find a workaround.
Thank you
Alexis
Currently our DALI controller can not match with DALI master 100%, we have some loophole for DALI protocol, the new DALI controller will be finished development soon, it’s hard to show you all compatibility about DALI master right now.
Hi there!
Any news about DALI Master compatibility?
I think the hardware of the DL-X is very good and capable, but the software could be improved. Any chance that you can upload the firmware to GitHub?
Best regards
Christian
