DL-X DALI 5-in-1 LED controller does not act on RGB command from Loxone DALI extension
As the title indicates, I’ve connected DL-X DALI 5-in-1 LED controllers (2 of them) to a Loxone DALI extension and led strips. The result is the same for both: I can control Tc (dimming and color temperature between cold and warm white), but not RGB. The leds are multicolor, I checked (if I change output mode of the controller, I can get random colors to appear, but this is of course no solution for correctly controlling both RGB and Tc). The mode of the controllers is set correctly to 5.
Importantly, I’ve added a DALI Touch Panel (DT8) to the Dali line, which gives the same result: I can control Tc, not RGB. The problem is therefore unlikely to be in the Loxone part of the installation, but rather in the controller.
Any ideas how this can be fixed?
Thank you, and kind regards, Bart
