A smart home helper--PIR Sensor (2.4GHz)
Hello Guys, Glad to introudce a smart home helper :grinning_face:
Its name is PIR Sensor (2.4GHz),model number:PIR-RF(Battery: CR123A 3V).
Not only it looks very cute, and also has the following powerful functions:
–Motion detection support smart scene automation and
intrusion warning
–Support to link with one or multi 2.4G lighting series
–Support to set “hold time” function
–Built-in high sensitive lighting sensor
–Strong magnetic mounting method
–Flexible 360°angle
More details please check the introduction:Mi Light PIR1-RF LED Light Controller | Miboxer
and the video https://youtu.be/47c1ilAN2kA
Thank you !
Its cute but not practical, especially in a commercial application; people can remove the sensor unit as it is hold together with just a magnet. Even at home, kids may do that.
You need an in-wall or in-ceiling version like this.
https://www.aliexpress.com/item/1005005631750389.html
Dear Sarumbear,
Good day,thanks for yor advice,We are also developing the similar sensor,
When the new sensor published,I will share with you.
Best wishes for you!
Thank you.
Cathy from Futlight
I want this sensor to turn the lights off when I leave the room but NOT turn the lights on when I enter the room.
Possible?
From the configuration video I see that I can set trigger nothing or a false scene when motion is detected. Then set it to turn off a scene when no motion is detected.
You show using a zigbee gateway.
Question: does the zibee gateway perform this logic or does the zigbee gateway only allow setup of the device and then is not necessary?
Question: does the zigbee gateway require to be always connected to the internet for it work?
